As long as the dipstick is manipulated correctly.....no foul.
No better feeling than knowing your dipstick is in the correct hole.
My dipstick is now bent in two places. Although it still looks good and works good would it bring me more pleasure if I had it on the other side?
Since Chris moved the black box to a more desirable location, there was no need of any manipulation on the dipstck. Only a gental thrust was needed.:baby:
Was lube required for it's new location?
Yes there was plenty of lube which is why it only required a gental thrust to drive it into position.
Would that be a "gentle" thrust or a "genital" thrust.... two very similar solutions to a common problem
Ah I see everytime I try and insert my dipstick in a new tighter location it usually takes me a lot more effort than a gentle thrust. I usually have grab it pretty tight and force it quite hard several times maybe ill try lube next time. Thanks for the heads up gentlemen.
I chose to leave the I out of the word for fear of reprimand or possibly worse. :angel:
I see you were the first one to catch that. :thumb:
Back on topic.
You are incorrect in your statement as the word gentle is an adjective and genital is a noun. One is a description and the other is a tool.
