drive pressure
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
would installing a gauge in the exhaust manifold help to determine
Drive Pressure?
i was foolin around with the computer yesterday and built a exhaust
gas flow rate chart,using vane postion upstream pressure downstream pressure and downstream temp plus tubo inlet diameter
useless knowlege probably:rolleyes: :D but thought i would ask
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
Actually it should give us some really good info. I really hope to do a drive oressure gauge myself. I am real curious how things like different exhaust housings effect the pressure.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
cool, i geuss ill add it to the long list of things to do
this gauge if/when i install i would like to hook up to my EFI
anyone done this yet and/or the EGT wire?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
where would be the best place to tap into? front / middle / back
couldnt you see like as high as 300 psi with big boost ?is there a ball park formula?
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
56
Tampa, FloriDUH
from what i recall, 1 1/2 to 2 times the boost pressure is ideal drive pressure, but most turbo applications are not that efficient and see 2~5 x's in the d/p
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I've never logged drive pressure yet. Something I've meant to do, but haven't.
You could also figure out drive pressure with 2 EGT probes. One pre turbo, one post turbo. You would assume pressure would be close to atmospheric at the post turbo and do the math.
The closer to the same temp, the lower the drive pressure.
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
Simon,
once you upgrade your turbo and have the vane position sensor unused you could hook it up there and just log that PID! No need to run wires inside the cab.
You could also do the same thing with the EGR feedback!
some of the gasser guys do this to log fuel pressure and I figured that we should be able to do the same. All you need is to locate some 0-5V pressure sensors...calibrate them and create a custom PID.
...but I see you already know as I was going to post a link to the thread over at the EFILive forum. :D
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Lennart
THATS COOL!!! i just read some of that post on EFI forum
so i just use the AutoMeter sesnsor and use the calibrations in the vane position table? or how do i set the varibles?
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
Simon,
Dooh!
One time it is bad to have a no emissions old school dumb turbo truck. I could change to a emission operating system but I would need to change the whole harness to? :(
I have been looking at a stand alone loggers like the ones from Corsa and RPM Performance. Any body know of any others?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Dooh!
you should still be able to ues EFI just need 5v of power to supply it
im going to investigate this more tommorow and let you know john
also im going to tap into the middle of the manifold
c_murray7313
Addicted to HORSEPOWER!!!
Apr 2, 2007
145
41
Ocean City, Maryland
drive pressure gauge install
OK folks,
i have ane more spot in my truck to install a gauge, i already have boost 0-60psi, fuel pressure 0-100psi, pyro 0-1600, and a trans temp gauge. ive been thinking of installing a drive pressure gauge but am having a couple issues with this.
1)where am i supposed to tap into the exhaust.
2)what type of gauge am i supposed to use, boost gauge, electric pressure gauge?
any and all help is greatly appreciated. thanks in advance.
chris
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
OK folks,
chris
i use a 0-100 psi electric fuel pressure gauge
tap into the manifold on the opposite side of the pyro
BD manifold works great for this;)
its a good idea to use some tubing to come off the manifold so you dont wreck the sensor
ill post some pics of what i used tommorow
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
chris
here is a idea, get a extra 0-100psi sensor from autometer and rig it in so you can switch between you DP and FP
cheap mod that way:) or else use the 100psi for the DP and get a 0-30psi for the fuel press
