What does everyone do to stop the flutter in the dp gauge?I was told to put a filter in line but was wondering if anyone has a part # or could send me in the right direction.Thanks in advance.
i've used either a needle valve closed way down or when using copper line pinch it down as much as needed, either way the pressure will still read correctly
you can make a filter with a 1'' ID 4'' long pipe steel-wool and some fittings and put a T'' fitting in the main line with a small section of line that dead ends pre filter. That will do the trick.
