Im running a Stock LLY charger with a BW in it (63.5mm) and the Standard exhaust work from Danville. When I hammer on it in any tune but number 1 my drive pressure gauge jumps up pretty fast, in fact when Im in my big tune Im running 75psi of drive and 35-37 of boost. I know this is pretty high and not good on my stock bottom end. I was wandering what everyoens thoughts were on removing the VGT and switching to say an S463. With the S463 I can still pull in 2.5 legally and the larger exhaust turbine will hopefully lower my drive pressure. At the same time whar are the chances this charger will finish off my stock rods, or will the lower drive pressure help them live a little longer.
