What size drill bit do I need to use for 1/8" npt?? Thanks
djms New member Dec 25, 2006 263 0 0 Houston tx area Feb 21, 2009 #1 What size drill bit do I need to use for 1/8" npt?? Thanks
ruffmanatv Yeah, its got a D-Max! May 9, 2008 3,640 0 0 46 Van Wert, OH Feb 21, 2009 #2 21/64 drill bit.
djms New member Dec 25, 2006 263 0 0 Houston tx area Feb 21, 2009 #3 Thanks that what i needed to know!
A Alligator New member Nov 9, 2006 1,919 0 0 48 N. Idaho Feb 21, 2009 #4 "R" bit is the actual bit type for 1/8" NPT taps. 21/64" is the closest to that size though. You can get "R" bits at a nut & bolt supplier. Last edited: Feb 22, 2009
durallymax New member Apr 26, 2008 2,756 1 0 Under The Hood Feb 22, 2009 #5 ^^^ exactly. If you lost your 21/64, 11/32 will work but its a touch larger
malibu795 misspeelleerr Apr 28, 2007 8,233 548 113 42 in the buckeye state Feb 22, 2009 #6 durallymax said: ^^^ exactly. If you lost your 21/64, 11/32 will work but its a touch larger Click to expand... i have made a 5/16 work with a 10x1.5 tap :rofl:
