I have a 3/4" NPT fitting I need to use. What size drill bit and tap do I need to get? Whats the difference between the 3/4-10 and like 3/4-16 taps etc..
Thanks
Thanks
Yes the tap mentioned above and a 3/4 npt tap. The tap will say 3/4 npt on it. Tap it some and test the thread. It should screw in 3 to 4 full threads by hand before it gets tight. If it does not get to 3 threads then tap a little deeper. Once you reach that it should be perfect. apply some thread sealant compatiable to what is going to go through the line and your set. In the trade it is usually 3 1/2 turns to be right. Sprinkler Fitters aka Puzzle Fitters go about 4 to 5. TheyThey like to crank in there pipe fittings.
Brian
In post #2, I gave you the drill bit size my bit/tap chart shows! 59/64 is the next size larger drill bit FWIW.
What material are you taping, the 59/64 would be a good choice if it's hard material Ie 321 SS.
I think he is doing a DIY twin setup so i would assume he his tapping the oil drain , unless this is for another project ?
