Drag racing questions?????
02duramaxfan
May 13, 2013
25
virginia
Ok so I finally made a few passes on my new set up and wasn't happy about the results...i just bought the truck with a cracked piston and just got it put back together... i have
Built motor
Empire alt firing cam
S475
60% injectors
Dual pumps
So cal heads
Bid dipper trans 1055 converter
20x9 rims on 420s... I know there heavy
The truck does have 4.10 gears as well.. It use to be a pull truck with a rear locker
And so on....
But anyway wants everybody doing launching this thing I kept cutting shitty 60' all night.. Maybe to much air pressure it kept trying to push through the brakes with holding barely any boost???
It's tuned by Danville performance and in between shifts I noticed that it defuels... Should it not?? i mean i only trapped 95mph which i thought sucked for all it has done to it
I'm just trying to learn how to get the most out of this truck.... Any input would be greatly appreciated.. i would like to hit low 7s with it
02duramaxfan
May 13, 2013
25
virginia
i believe like 2500 or 2600 rpm but its kind hard to tell i feel like i cant make more then like 10 to 15 psi before it just keeps pushing through...... before it cracked the piston in went 7.30 at 98..... with diffferent tunes on it and i went this past weekend and only trapped 95 maybe the tunes are not right on it.
Harbin_22
3,858
Southern Indiana
What are the specs on the 475? What's the truck weigh? Were you spinning when you left the line or what? What was your staging method? Did you build any heat in the turbo before you brought it up? The 4.10's really aren't helping any with staging. Might want to try a second gear start.
2,137
4.10s may be why you are pushing through the breaks real easy. And like mentioned earlier, try a 2nd gear start
02duramaxfan
May 13, 2013
25
virginia
It's a 83mm 1.10ar and they truck did jump and hop off the line I just feel like it would have trapped higher then that... The trans is fine before it the piston the cracked... It ran 7.30s at 98 at that time it had a 476 and different tunes I wouldn't have thought it would make the big of difference the truck has been data logged twice now...... And when I say defuel at shifts I mean it doesn't smoke a bit when it shifts I figured it would keep fueling non stop
Awenta
4,090
CT
You would need a tune that started you in 2nd. It's harder on the converter. The Allison needs to defuel.
02duramaxfan
May 13, 2013
25
virginia
Ok thanks that makes sense the tcm is currently tuned.. By who though I have no clue
By the way it sounds would anybody be interested in my 4.10 with a Yukon locker or hell maybe even sell my front locker as well
1,866
Whats your suspension setup like? Shocks, Tbars, etc?
What tires -- those 420s? What pressures?
cat_dr.
257
Jackson,Al
I'm having similar issues with mine. Can cut better than 1.9 60s and can't leave hard without it being all over the place
02duramaxfan
May 13, 2013
25
virginia
I am lowered on a djm 3/5 drop and qa1 shocks all the way around... I was wondering if I had to to much pressure they were around 40 to 45 which is high
02duramaxfan
May 13, 2013
25
virginia
It was already tuned when I got the truck.. I believe it is tuned by moonshine since that who's tunes were on it before
I mean the converter feels like it lock up really good
DMAX497
Sep 27, 2012
398
Utah
Are Tony's ( MOONSHINE ) ECM tunes in the truck right now as well?
His ECM/TCM tunes best shifting tunes I've ever had...
02duramaxfan
May 13, 2013
25
virginia
No there not I assume the tcm is still his tunes... Tune 1 through 5 all felt the same they all trapped 98-99 so after it broke I just decided to start fresh with it
Worst case I guess my mechanic still has those tunes I could always put them back in
I only changed three things to whole truck when I put back to together
1 I went with Danville tunes
2 it had SoCal 6480 standard can - I went with a empire stage 2 alt firing cam
3 it had a gt42 turbo that was shot- so I went with a s475
