Drag racing questions
2005LLY
Sep 18, 2011
379
Well the local 1/8th mile track will open in the next month or so and I've added quite a bit of stuff to the truck didn't know if you guys had any tips I could try out. I was running 8.3s with shitty launches I've fixed that problem and now have added roughly 100hp what times should I expect? I am running nitto 420s I've air down the tires to 35 in back and 40 up front didn't know if you guys had better luck at 60ft times at certain psi, as far as launching what rpm do you all usually leave at?
Dylan
2005LLY
Sep 18, 2011
379
Stock turbo/ lift pump tunes. Yeah I've got a built trans, truck dyno'd 520 with that set up, I told nick to keep it around 650 with the new set up. I stripped the c2/p2 gear in my trans so it's getting rebuilt with all billet parts. Just didn't know what I should expect time wise adding 100hp
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
7.5 to 7.7 maybe even better. Just my guess. Try 35 and 30 in the tires. I cut a 1.82 like that and should be able to do better.
