LMM: dpf delete help
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
just put a AFE 4'turbo back dpf delete exhaust on my buddy's '10 lmm. We also install the ppe standard on it and put it on level 3. Now after i installed the tuner the CEL was on and had a 2455 code. I figured it was the dpf code. Drove it down the road and truck ran fine so we put it on level 2 and the tuner frozed up on installing tune. Tuner is supposed to take care of that.So we pulled the fuses it says to pull and then the tuner froze up vin #check. Any ideas on what to do. Also truck will not start now even with all the pulled fuses back in
Dec 2, 2006
1,696
TN
PPE standard will not do DPF delete tunes. As far as programming, you'll have to contact someone at PPE's tech line as they know how their tuners work and I'm sure they can get you on the right track.
duramaxican
Feb 19, 2011
DADE CITY FL
Plug your programmer back in,and return to stock ,and after you load your factory setting,try level 2 you really need a ppe hot +2 for the dpf the same thing happened to me and thats what i did to fix it.
