LML Dpf back exhaust
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
It should not void it but if you have a dealer that does not like you work on it they can blacklist it.
Also what is the point of a DPF back one it does nothing but change the sound. It won't help make power or ever lower EGT.
Denalimax
May 19, 2013
24
Red Rock TX
Yeah that's what I've been hearing but once again it's all about warranty if I deleted all that I'm sure it would void it. Right??
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
A DPF back shouldn't hurt the warranty as it shouldn't affect any of the emissions system. On the other hand, you probably won't notice much if any change in sound with it. I know the LMM's with the DPF on them straight piped back are still VERY quiet and you can't hardly tell the difference between stock.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Yeap what they said,kinda like stuffing a sock in your pants......looks the part but doesnt do anything :spit:
Just joking with you but i would probably just wait till the warrenty is up then get a full exhaust for an lb7 i believe will still fit I THINK,then find the correct tuner to make it rock and roll.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
LML's are straight piped after the DPF anyhow. It would be pointless. Plus there is no 'junction' to unbolt it as it's all one piece.
