LMM: Dpf and egr deletes
pornstar dancin
pornstar dancin
Oct 23, 2012
251
almond ny
Hoping one of you guys can help or share some info
My dpf just left me dead on the side of the road yesterday so bring on the deletes.
So my question is , after I do dpf and egr will the truck run right until I get my tunes and switch installed or will it run choppy or in limp mode
hrlyguy2
Dec 2, 2011
274
IL
When I did my deletes.My truck ran great for about 2 months.
Then kept getting reduced engine loss code every 5 minutes.
Kept clearing the codes on the CTs all the way home .
hrlyguy2
Dec 2, 2011
274
IL
Gut the dpf out.
Still need it hooked up or find some one too turn it off.
Still will get codes
pornstar dancin
pornstar dancin
Oct 23, 2012
251
almond ny
Yes took it to dealer yesterday and tried a forced regen and it was so plugged it wouldn't even do it due to not being able to run for more than twenty seconds. Also couldn't get the rpm to get any heat to burn it out
pornstar dancin
pornstar dancin
Oct 23, 2012
251
almond ny
So I went to do my egr delete yesterday and when I popped the hood I noticed my upper radiator hose was sucked in flat. So i opened the reservoir cap and it let it back out. Is this normal or possibly a sign or somethin bad?
