Help: door speaker amp install ??????
bigmonkey611
bigmonkey
Jan 11, 2013
Waterford Wi
Would it be worth trying to tap into my bose amp wires to hook up a 4 channel amp for doors speakers. Or should I just run all separate wires to the door speakers and get it over with. I heard I can just tap into the factory bose amp wires instead of running all the other wires. True or false??? Im hooking up a four channel alpine 75x4. Thanks for all the help in advance. Yes I have upgraded my door speakers. I believe they are jl audio c3 series speakers.
jlawles2
1,054
Danbury, TX
The only issue is that you will loose the chime.
But I agree that running larger wires is better. Bose amp is somewhere around 35 - 45 amps.
