Found this from instructions from Go Parts:
Tools required:
- 7mm socket/driver
- Flathead screwdriver
- Torx Driver (small)
- Needle-Nose Pliers
Step 1: Open the vehicle's door.
Step 2: Pry and remove the interior door lock's bezel.
Step 3: Pry and remove the trim panel that covers the side mirror's mounting area.
Step 4: Pry and remove the interior door handle's bezel.
Step 5: Pry and remove the retaining pin (1) near the door hinge.
Step 6: Remove the screw cover (1) near the door latch, exposing a Torx screw. Loosen and remove this screw.
Step 7: Loosen and remove the 7mm bolt (1) inside the interior door handle.
Step 8: Loosen and remove the 7mm bolt (1) inside the interior door pull.
Step 9: You can now lift and remove the interior door panel. Disconnect the wiring harnesses (5) attached to the back of the door panel.
Step 10: To reattach the interior door panel, simply reverse the removal process.
