Doing twins, need help on gauges
05Monsterdmax
May 31, 2011
119
At the moment i have my 60psi boost gauge, 35psi fuel pressure gauge and then my 2k egt gauge. Ordered me another 60psi boost gauge to monitor the second turbo, and had a buddy recommend a drive pressure gauge??? Ive never personally dealt with drive pressure gauges, so im unfamiliar with how they install etc. Idaho rob will be doing the tuning as usual, so do i need the drive pressure gauge? And any links on a how to on installing one. Ive searched everywhere and not came across a single instructional thread, kinda crazy. Thanks.
Noreaster
2,910
Cape Cod,MA
Typically their tapped into one of the exhaust manifolds but you will get needle flutter that close to the exhaust ports. I ran 5ft of 1/4" tubing in a coil to dissipate heat, made up a filter with some steel wool inside a coupling before I switched to 1/8" plastic tubing running to the gauge.
100psi gauge is the normal choice
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Their is alot of threads about drive pressure gauges. Like said above basically you are just running a line to the exhaust manifold. Coil copper line for a foot or so to cool the air then convert it to plastic boost line to the gauge:thumb:
Harbin_22
3,858
Southern Indiana
Yeah I need to bump it up. Cool thing with isspros is all I have to buy is the head, all the senders are the same. Guess I could put my 100#drive pressure head there.
