I am not sure if this is the NSBU or not. First off the truck will not start in neutral, only park. Second if I was to try and manual shift it it will do fine till i get ready to go from 3rd into d the little square around the gears goes away when i try to put it in drive. It shifts into 4th but not 5th. The only way to make it go in is to put it in neutral and then shift it back to drive.
This is only when I am trying to manually shift it. It shifts fine if you just leave it in drive and go.
