It's the clamp that holds the coolant tube to the underside of the water pump thanks
Sent from my PC36100 using Tapatalk
You see the cut out slot in the clamp? There is a rubber nipple if you will on the tube which doesn't let me use a normal clamp I have already tried
Why can't you just order it thru GM
