Is it possible to disassemble the stock turbo while its still in the truck? I am wondering if its possible to remove just the compressor housing.
Thanks.
Thanks.
Tom you still want that extra turbo i have? There are bolts all around, that hold the comp cover on- it will be a real bitch to try to get just the cover off. Would be easier to just take the whole turbo out than risking dinging up the compressor wheel
How does the compressor cover mate with the cartridge? Are there bolts?
I ended up putting a new cartridge in it and putting it back on the unit. There was some wear on the compressor side of the housing but not bad enough to require replacing the entire turbo.
It has a T6 flange on it-not the most ideal set-up for our trucks But yeah-4" inlet and a 5" outlet would make for a one nice big turbo!
