Hi Guys,
I'm actually running 11,8X with constant 1,61-1,68 60ft on street tires.
I just received my ranchos 9000xl so it might help a bit dropping the 60ft more but i am looking for some tires to get in the 1,5X range and improve overall ET.
Since i didnt found any PYO, i might buy pro comp 16x8 or 16x10 wheels.
Since they are wider than PYO, i have now a big range of choice like cheater slicks.
I'm hesitate between a combo of 16x10 with 30x14 cheater slick OR 16x8 with 28x11,50 cheater slick.
I'm trapping 113 mph actually and my main concern is that if i add a dual CP3 and get 116-120 mph trap, will those 28" inch tire will ran out of gear and have negative effect on the ET???
On the other hand, does the 16x10 rim with 30x14 cheater slick might be too wide and drain some power out?
I know that on stock cp3, the 28x11,50 will be more than ennough for my needs... But considering more power for next year, are they gonna be at their limit traction wise and trap speed/gearing?
Actual mods is : efi live, sdp twins, stock cp3, 45% nozzles, trans built, etc...
