Working on a way to run dual digital MAF units on a E35B. Basically taking two MAF sensor signals and combine those values into a single output with a total fed to ECM.
To do this, I plan to use the new style [and cheaper] GM 15865791 MAF. Some guys over on a Corvette Forum thread mapped out some higher flow range options a while back. However our E35B - B0205 table tops out at 8696Hz, while the new MAF produces up to a 12,200Hz signal. EFIlive limit is 1000G/s, so we have plenty of scale left on that side. Needing a Cax file to re-scale the MAF table.
I've done the ground work to verify everything else should work. Using a square wave Hz generator to check the ECM limit, found it will recognize up to 14818Hz input value. Well within the newer MAF range. However, once that value exceeds 9.2k Hz, the G/s PID reading falls off to zero. Which tells me it would likely set a MAF out of range code. So looks like the B0205 table is our only issue. Values shown in pictures attached.
I posted a request on the EFIlive forum, but figured better chance someone here could help with writing a CAX file.
Tks
Tks
