different sized tires front/rear
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I was thinking about running a taller tire on the rear of the van next time I go to the track.
It would only be on the rear as the 265's barely clear on the front.
besides throwing a 'check ABS', is there any other negative effects?
548
i am running 285(33) up fornt and 315(35") no abs problems
now 245(31) and 35s WILL make the ABS go MAD!!
AWD would deffenetly hate you.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
just remembering dynoing the truck and the dash flahing the abs or service brake system warning at me. everything else was fine.
yea, i dont have to worry about awd
548
if your worried pull the 60A maxi fuse for the ABS the ABD and parking brake light will come on.. and deactivate the ABS system
ripmf666
15,123
14
47
Wentzville Mo
Only reason that happened is it was getting a speed sensor reading from the trans and not from the front wheel sensors, My truck dooes that on the dyno also.
