Upcoming on a build i was going to do next weekend. my trucks an 04.5 lly 4x4. I was planning on just doing a gmax 5-3 kit and converter along with mikes pressure regulator spring and eliminating converter knockdown. truck has max effort tuning but will be daily driven a 60ish hp tune. anyways, a friend of mine has a core 2001 trans and its 2wd. Its super low mileage (20k). I know that I could basically have the entire front done and wouldn't be in any kind of time rush to go through it. My question is, is it as simple as swapping my extension housing and output shaft over? if not, what all would have to be swapped?
I also read something about late 03' they swapped cooler line sizes...is it possible to just swap the cooler quick connect fittings or is the case itself different?
I am just curious as I could built it as I have time or come up with any troubles. Thanks
