Did a search no luck questions..............
5,835
Lbz/lmm/lml are the same size and the largest. They only fit those heads.
Lb7 and lly are the same size and only fit those corresponding heads
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Any intake runner will fit any head. But if you use lbz+ intake runners, you have to use an lbz y-bridge. If you use lb7/lly intake runners, you have to use an lb7 or lly y-bridge.
Lb7/lly intake runners will not work with an lbz+ y-bridge and vice versa.
ikeG
Oughta Know Better
Apr 19, 2011
2,465
147
Western PA
www.facebook.com
LB7 do not have the dent or step in them at the turbo, so if you're running a pedestal-style turbo on a LLY you could switch to those and reuse your y bridge.
5,835
They will fit but lb7 fuel rails will not work on lly intake runners. Not sure of other years
Not sure why I posted they only fit corresponding heads. Saturday brain fart
