It's a long story but here it is. I'm driving my truck to work this morning and it acts up like an injector. It gets noisy and white smokes for a couple seconds and go away. The second time it does this I have driven another 70 miles and it does it a lot worse and it last for 10 seconds or so. The final time it does it is about 10 miles down the road and it isn't as severe in noise or smoke but last until I shut it off. It will not start when I try to crank it again. I had it towed home and began doing some test. Fuel return, compression test, and will be doing a high pressure leak test. When logging it only makes around 275 psi cranking pressure which isn't enough to fire it. Give me some more ideas. i believe it may be an injector but it may be the FPRV too. Its a tough one to figure out when you can't start it. All help is greatly appreciated.
Shane
Shane
