Deviant trans lines leak
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Anyone know a good remedy to get my trans lines to quit leaking at the radiator fittings?
Brand new kit from deviant. Havnt had time to call, just wondered if there was a quick easy fix before I waste their time.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Pic of how it is now. O ring on sealing surface and under the big washer
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I had to give mine an extra oomph after I first installed them they did the same kinda thing but they've been trouble free for almost 5 years now
oscyjack
May 7, 2016
775
Northeast
Hope their a good kit. DRP has good quality usually and what I plan to replace mine with
When the extended warranty on the lines goes out
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
It's a great kit. Only issue I've had with three sets of them. Tried it a couple different ways now.. guess I'll try tightening the piss out of them even more
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I know your not a ratard but is the oring rolled in there
I'll check tonight after work. Pretty sure not, had it out a couple different times trying different things.. might just have to get an o-ring kit and find a different size. Pretty sure this radiator is aftermarket judging on the cooler fittings in the tank.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Changed o rings and tightened the piss out of the fittings in the radiator.. I'll post pics when I get home.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
How it came off the truck
Swapped some o-rings around and got one size bigger for the inner
Hopefully that takes care of it.
