How have you guys gone about removing the abs block on the frame rail under the drivers door? Instead of just putting a plug in the back I'd like to do away with it all together, and if I can retain the factory master cylinder. Could I just run a line to each front caliper out of the 2 outputs on the master cylinder? Thanks for the help
