delete or not delete
59 camaro
Aug 9, 2009
209
hey guys just had a few questiond b4 i go and do anything to my 06 duramax van? does anyone know what the stock size exhaust piping on my van (it looks like 3 inch to me) and since i just want very lil performance out of it but more of a tougher exhaust sound since it will be used for work should i just delete the stock muffler and replace it with just a pipe of the same size or should i get mbrp 4'' muffler? remember just want it basically stock exsept for the louder exhaust.... will this be throwing black smoke like crazy if i do so? thanks in advance
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
muffler or not will not change the amount of smoke you get. If you are looking to do it on the cheap I would delete the cat and muffler with straight pipe. If that's too load for you then add a muffler back in.
9,906
152
:yup:
The only way you will get more smoke by removing the exhaust is if you have a DPF and you remove it.
9,906
152
Moved here;)!
Your DPF is inline with your exhaust. In laymans terms, it's similar to the catalytic converter in a car, but for a different reason. To remove it, you need a programmer to turn off things like regeneration mode and some sensors that are programmed into your ecm.
Don't worry-your '06 van does not have this:D
They were installed on '07.5 and later GM diesels. Lotsofmiles is one of the redheaded stepchilds on this site with a van also!:D He would be a great guy to compare notes with!
9,906
152
One issue you may run into if you straight pipe it is you may throw some EGR codes for insufficient egr flow. I had this problem on my truck but there are ways to get around it-even without having to purchase a programmer.
9,906
152
If you are replacing the piping from the turbo downpipe back, then bigger is better.:);)
Otherwise just buy the aftermarket 3". It will give you a nice exhaust note which is what you are really after the way I read it!:D
Myself, I have the diamond eye downpipe, and then I straight-piped it back with 4" from there. And yes it is loud!!
