Like the title says. My 2002 D/A defuels or sometimes has a dead pedal in 1st gear low range. Sometimes I can push the throttle to the floor and rpms won't increase at all and then the tranny will shift into second and everything will work fine. This seems to be most noticeable when I have 5er in tow on back roads. When the dead pedal isn't there, it still seems to be defueled in comparision to high range. I am running a ppe hot + 2 et on level 8 with defueling enabled. Any ideas? I will try hooking up the scan tool and logging the data, but which computer should I be looking at, engine or trans?
