Help: Debadging
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Hey guy's just wondering how to debadge my truck without breaking anything because I might want to put them back on or somewhere else. I tried using some adhesive remover and tried tugging fairly hard but I felt it was probably going to just snap a peice off. I'm just trying to get the 2500hd part off and leave the duramax badge on. Thanks:confused:
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I would not use fishing line it can burn the paint. Spray some adhesive remover on and I usually take a plastic scraper and mask the edges a few times then put a cloth over it. You can work it under the edges of the badge without messing the paint up. Once you get a corner up just peel the badge off. Then hose down the sticky stuff and use an eraser wheel. This is the fastest cleanest way I have found and I have taken LOTS of badges and moldings off.
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
if you put the fishing line under the badge and not on the paint, it's not going to burn it.
It's a lot easyier than masking and covering everything up for 2 minutes worth of work. I broke a badge with paint scraper:hug:
Jack Bauer
May 3, 2008
58
CT
I used a bondo applier and 3m adhesive remover. They didn't come off in one piece but I didn't car. Took all badges except the Duramax one and 4x4 stickers.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Yepper. I like that method. Ive seen fishing line do ugly things but I have seen it work. I just like the thin plastic better.
radvans
242
SoCal
Have thought about doing this...but truck is an 02...will it still work or will I have bad paint fading...truck is white.
9,903
149
3m pinstripe wheel makes it so much easier to remove the glue
This is the best for removing the glue.
Your gonna F-up the badges guaranteed unless you are anally careful when you remove them.
Here's a pic of mine de-badged-you can't tell the stickers or ugly door trim were ever on.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
To get my badges off I heated them up with a heat gun a bit and then sawed them off with fishing line. I ran the fishing line between the badge and the glue, trying to keep it away from the paint. Then I was left with just the glue which I heated and then rolled off with my thumb. I then ran a clay bar over it. To get the door moldings off I heated them up and got my fingers under them and slowly peeled them off heating as I went. I also peeled up both ends of the door moldings before the middle. I have heard that if you just go from one end to the other and pull it off too quick at the end it can leave a very small dent. Not sure if it's true, but I didn't want to risk it. Hope this helps, sorry for the long post. :)
