LB7: Dealer says injectors not covered, pdf of tech 2 included.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Can someone please help me make sense of what the dealer is doing here? They are saying since his truck makes 159mpa's and anything over 158mpa is not covered. He is having white smoke at idle, no fuel in oil. The dealer did not do a return flow test either, just hooked up the tech 2.
Attached is a pdf of what the dealer sent my uncle while he is in california, his truck is currently in Lousiana. Thanks
  • Jim Lanoha.pdf
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Thats weird that their going by the regulator pressure & not checking balance rates.
Not only that, but balance rates alone is not enough to get injectors changed. I thought the bulletin said at one time the return flow must be out of spec before changing out the injectors would be covered.
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
special policy requires us to have a snapshot taken of the pressure. According to gm if the injectors are leaking they will be unable to make max pressure. Your buddy probably just has 1 or 2 clogged and not cracked...
Josh2002cc
That Uncle
Apr 2, 2007
1,832
So in your opinion after working at a dealer, would you say the "injector cleaning" they want $350 for is worth it or not? When I think of a "injection cleaning" I think rip off at a commercial tire/lube joint.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Yeah, that seems odd. Whether you can successfully command full rail pressure at idle just means the CP3 ain't shot. It can deliver several times the correct amount of fuel at idle. So if an injector is leaking, it won't show unless it's way bad.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
On page 3, under the heading "Correction" it says that if the truck is reaching full Mpa's while at idle then "the technician should follow SI diagnostics" which leads me to believe the dealer is using the special policy for the cp3( http://www.duramaxdiesels.com/forum/showthread.php?t=4729 )pump to deny his claim on the injectors.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
That's a 6.5 TSB?
I would run, not walk away from a dealer who apparently isn't really familiar with the Duramax engine. MK Smith is good (in Chino, CA), Victor GMC (Corona) is bad, maybe some others could chime in.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
That's a 6.5 TSB?
Pat the truck is in Louisiana;)
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
If the rail pressure is commanded and goes to at least 158 mpa then the special policy for a full set of injectors does not apply end of story with GM.
As far as cleaning injectors for clogging and excessive balance rates the jury is still out. You could do the same thing by buying a good fuel system cleaner/treatment and running it for some time and see if the smoke goes away. Then have the balance rates checked again.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Another thing is if their not testing properly (ie. vehicle hot at operating temp) they will get false readings if things are marginal.
racinmike77
Sep 14, 2008
1,029
MD
I was FORCED to pay to have my injectors cleaned by the dealer, 5 miles later I FORCED the dealer to refund my money and replace the bad injectors.:D
duramax3388
447
Zanesville Ohio
i just got told that mine had a chip on it (i took it off before i took it in but the boost gauge and pryo gauge says it was a chip on it:rolleyes:) and that they would not cover it under warranty and went on to say that for it to be done on my dime they where going to cost 4800$ :rolleyes:
Josh2002cc
That Uncle
Apr 2, 2007
1,832
I was thinking about that, but what if he pays the money and then it doesn't work he is out cash and still has a truck that doesn't work. Kinda sounds like a lose lose.
The truck in question has a chip and like you my uncle removed it before going to the dealer, they have not said anything yet. I got my injectors replaced and I use efi live have guages and a single stack, dealer didn't say anything. I was lucky.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
tell him to pour a gallon of diesel fuel in the crank and take it to the dealer:rofl:
That is not a very good idea IMO. My uncle asked me if he should do that and I advised him not too because of the damage diesel fuel can cause while in the crankcase. Just doesn't seem like a good idea, I could be wrong though.
duramax3388
447
Zanesville Ohio
yea it just kinda sucks because now i have a 20,000$ yard ornament till i can come up with the money to replace them. unless i can find a dealer to do it for free i just don't feel like taking it to every dealer in this area just for them to say the same thing as the first one and then ask for 200 bucks for looking at the truck. i have been thinking of taking mine and having them rebuild at a injection shop if i can find one and its not going to cost a arm and a leg.
