A little explanation about the truck and the write-up from dealer.
Truck had be throwing a 0087 alot. First couple times it did it I thought must be the fuel filter clogged. Then it did it once or twice with a fresh filter.
I finally took it in because it was almost out of warranty and it died on the side of the road.
When it died I was out in the middle of no-where arguing with the towtrck about where I was (I could see the two street signs, but he said those to roads ran parallel and didnt intersect)
So I finally got it figured out and running before the tow truck got there.
When it died there were no codes, no CEL.
I swapped the fuel pump relay with the drl relay and the truck fired right up and had the 0087, 0230. I had never had the 0230 before.
Also the receipts says codes 401, and 0461. The 401 had happened 1 time and long before the 0087's started showing up. But as long as it was going in with only 1000 miles or so left on warranty I wanted it all checked. I had a short list of everything and all the codes I wanted checked while it was in.
Whatever they did on this receipt fixed the 0087's. I haven't had a singal 0087 since. maybe they just disabled it:rofl:
Also at this time the truck had the 6gun, intake, cat-back exhaust on it. egr wasnot blocked at this time.
edit: And I highly doubt the fuel filter was clogged. It had only been on for about 2000-3000miles. I dont have the steering wheel controls, and never reset the fuel filter life indicator until it shows up.
