Danville turbo questions
2005LLY
Sep 18, 2011
379
I'm looking at danvilles stage 2 2.5" stock appearing turbo for my truck, says it's capable of 700hp what is needed to achieve those numbers? Also what would be a good turbo to twin over it with? Looking for good streetability but a lot of power.
Built bottom end, 100% exergys, 10.6 stroker pump, Banks intercooler, pro fab manifolds and up pipes, max spool springs & push rods. Trans is full billet. So I have everything, but the truck will be a 2.5 truck, then when I'm bored throw on a twin kit to make some serious power
Woody87
58
Mt. Vernon, IN
I've got everything you do except built motor and 100 overs. I'm running 10mm exergy and exergy 45 overs. Don't know if you have full 3" plumbing and bridge, assume you do. I do and I made 692/1250 on the same charger you are looking at. Go with the TCT wheel option too. I'm looking to twin it as well once I build this one.
2005LLY
Sep 18, 2011
379
Great to hear! What is the TCT wheel? I would go with a big s400 charger but this truck is meant to be fun and it'll never be a trailer queen puller so I want something fun and responsive, that's why I was looking at the vvt
