What's your power goals? This is similar to what I want to do, but gate the vvt to keep the drive pressure & EGTs down.
I am thinkig about twinning my d'ville with an s480...thats the combo I have in mind but would like to know what some of you all have to say in the matter such as other turbo options maby or the pros/cons of this idea
Why would a person want a wastegate on a VVT, Trent? Seems like it'd be redundant.
A VVT turbo with the vain's all the way open does not flow enough IMOP , especially in a twin setup, or a guy wanting to push the stock turbo or spray it , waste gate would be a lot cheaper than after market VVT and think the gains would be be good for the $$ spent .Ever wonder why the Stock LB7 turbo can make more power with a much smaller compressor wheel ?
I have a bolt on Waste gate kit coming for the VVT crowd shouldn't be too far out . S480 /Gated VVT could put down some decent #'s IMOP
Should work fine , VVT twins work decent , but are never as optimal as they could be with a better flowing turbine or waste gate
No, never did...I just know it works pretty well.
So do you modify the tuning to keep the vanes stationary and let the wastegate do all the work? Sorry, Im just not seeing it.
you need a tester for the new wastegate Trent
Yep, this is what I do when I build my current sets, by building a waste gate to go around the stock VVT to the S480. MPI did this on their first kits (but because it was before the veins were controllable). It helped with drive pressures in the trucks I have done my installs on, EGT's are lower (not that they were bad to begin with), and should make that little VVT happier in the long run. My opinion is that it's worth it. It is more cost, but the benefits are there. Another thing is it isn't any extra work to bolt the waste gate set-up in if you are already there installing the twins. It's not hard to "tune" the waste gate and dial it in.
It would not be possible on a truck that currently has twins , it would require "some welding" to tie it into the exsisting hot pipe . But if you know some one to take care of that aspect we may be able to work something out .
not hard to do it , but to do it right and gate both sides IMOP is the only way it should be done . Most I have seen done are using the EGR port on the up-pipe and that is not the route i will be going .
sorry to continue the hijack BUT what about what about single stock VVTs? what im getting at is there must be an optimum vane position for the very best DP/boost ratio. however that position may cause overboosting with additional fuel. using the wastegate would allow you to use whichever vane position proves most efficient at x level of boost and direct additional unneeded exhaust around.
started a thread about it a while ago but it didn't go very far as i didn't have the funds to test the theory
No. You still use the veins to get the quick spool up, and have them there to do grade braking.
No. You still use the vanes to get the quick spool up, and have them there to do grade braking. The waste gate is there to help use the energy to spool the bigger turbo once your VVT can't keep up with efficient flow through the turbine housing ("excessive" and hot drive pressure).
You have to tune the waste gate for your liking.
I have mine referenced and controlled so that I can still have my crazy grade braking from the VVT for towing (higher drive pressure lower temp EGT, low boost), but it will still waste gate around the VVT when there's "excessive" hot drive pressure, cruising (sometimes steep grades I see it open depending on tuning), towing (grades), and accelerating. There's a few ways to do it (reference and controlling wise), and people definitely have different preferences in how it acts. Some don't like grade braking, some do, etc.
-Dave
