expensive to do a 4wd and get decent front end travel. even then your limited to CV angles and you can break the cages or axles easy. Not to metion your turning radius will absolutly suck if you get a good kit that has a good amout of wheel travel. anything over 14-15" means the uniball in the UCA or spindle will have to be turned vertically to acheive the travel desired, thus you limited in your steering. turing radius will diminish with extended arms anyway. then you have your rod ends and uniballs that dont like high mileage either.
Prerunners are alot of fun but need a decent amount of upkeep as well. been there, done that with my only daily driver. i put 60k mainly highway miles on my old 00 GMC new body style RC/SB with a fugitive fab LT kit, 35s on beadlocks, deavers out in the rear and king shocks all around. i miss it but wouldnt daily drive it again
btw, if you come across a white gmc like i mentioned, let me know. i like keeping tabs on it as id like to buy it back one day
