I finished my head gaskets and took the truck for a drive. Came home and noticed oil dripping off the driver's side rear of the block. I was able to get under the truck and shine a light up, and I could see a small gap between the top of the head and the valve cover.
I assumed that I just hadn't seated the valve cover correctly, so last night I loosened everything up and readjusted, then started with the bottom row of bolts, tightened, then worked my way up to the middle row, then the top row. Took the truck for a test drive last night and everything seemed fine, but when I got up this morning there was a decent size puddle of oil under the truck again, and it looked like oil had been seeping out of the rear driver's side corner of the valve cover all night.
I quickly stuck my head under the truck and couldn't see the same gap that I did yesterday, but didn't have time to look closely sicne I had to get to work.
One thing worth mentioning...when I was messing around with the valve cover loose last night, when I had it seated on the two pins, I could very slightly rock it back and forth, almost like it was warped or something. Anyone have any insight? I did reuse the VC gasket when reassembling from the head gasket change, but everything looked fine when I inspected it before putting it back on.
