d rated tires...
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
D rated tires are fine. The H2 takeoffs that so many people run are D rated. Most street tires are D rated also so you will be ok.
Jun 28, 2007
3,259
NE Pa
If you go with something like a D rated 285 they actually can handle more weight than the stockers. I have ran several sets on my truck with no problems.
Righteyeblind
712
Fairbanks, AK
Just look at the load carrying capacity. D rated 285/75R16 have a larger air chamber which carries more load. 245/75R16 even though they are E rated dont have the size air chamber as 285 so the 285 carries a larger load
Colt
Jul 23, 2010
523
D tires ride so much better than E it's worth the time in the cab without all the E bouncing. Most could run D tires if they only tow a few times a yr. Most trucks just run around empty major part of their life.
