how much HP can i put on the LLY, before i need to start thinking about upgrading engine parts. I've heard some people running up to 500RWHP before changing anything. I know i will have to upgrade the tranny. Any thoughts?
375 RWHP for a 7.3 Ford is a big number. They just aren't that durable of a motor for huge power. And if it was a 6.OH NO then it was just a matter of time before she went pop.
i personally think alot has to do with how it gets driven. most guys dont get to the track or build there truck for "racing". if your not foot to the wood 90% of the time i think you will survive alot longer than most. jmho
There's a local 7.3 at 680hp on the stock bottom end and an S475. Runs low 7s in the 1/8th and pulls with it. He took 3rd in the Top Truck Challenge at the OBX Pro Diesel Challenge.
Back to the original question there are ALOT of guys running around at 500hp on LLYs. You can get that with a lift pump, shim and tuning. Then there are alot of guys running around at about 600hp with a turbo uprade or nitrous. And there are still other trucks at 700hp on stock motor. There's not a set hp number that causes things to fail, it all depends on the tuning and mods you use to get there and some on luck.
That is of course very true as well and I thought went without saying. Hell a stock trans will survive a 500+hp truck if you keep your foot out of it - but then you aren't using the 500+hp so what's the point of having that tune on there. I lived 5 minutes from a track that was open 2 nights a week and drove my truck like I stole it almost everyday - my stock motor didn't last me all that long.
The 7.3s Also need a girdle(s) to help keep the block from cracking/splitting in two down the middle like the 5.0 liters in the mustangs at higher hp levelsSome I'm sure will argue this point but the majority of experience I've had is that the tuning and where the torque is made makes a little difference (but torque is torque in the end). At around 575 or mid 1100s on the torque, I've seen the rods bend (from compression test results, however LBZs are slightly better but can't comment on the LMMs). ALL seem to run well afterward for quite some time, but the damage is done and it's a time bomb now unless the bending was extreme (windowed block instantly instead of latter). Maybe we can cross the 650-700hp range with out going into the damaging torque area and live? Don't know. Compression tests don't lie. I also found that in most cases, by the time studs are needed, so are rods.
As for 7.3s. Been around quite a few. I know most bottom ends don't live past the 400hp mark unless strengthened up (P.M. rods models were the worst for failure, some don't make it past 350hp). Some with the better rods have even seen 500hp for a very short time with ugly results. If any are wondering, contact Tad at Elite (close to me). He'll let you in on the skinny.
