The 502 HP tune made a maximum of 220 bar so far in testing, and confirmed what "Fingers" told me: The Optrand sensor is relative, and not absolute.
With the sensor static (14.7 PSI atmospheric pressure), engine not running, it reads .52 volts. But when the engine is running, the static reading (exhaust valve open) is .48 volts.
Well that can't be right, since with a rating of 0.00131 volts per PSI chamber pressure, that would mean when the engine is running, that would be about -15 PSI absolute, or better than a perfect vacuum. Truth is, it should be at least .56 volts or far higher due to drive pressure.
This means we can't look at things like changes in exhaust scavenging with this sensor, and perhaps means our readings will never be more trustworthy than ±10%.
NEXT, if you want to watch the Injector #1 fire, you need to actually map out Injector #2, if you are getting the pulse from the Bale Connector. Since it's a capacitor based injection driver, you are off 90° in the pulse.
Still haven't hooked up a decent TDC marker, so I'm using the injector pulse, which is advanced most the time.
