A couple questions about cylinder head work...
I'm pulling the heads off a LYY motor, probably next week sometime to replace head gaskets. Motor has ~108K miles on it and appears to be in excellent condition other than the HG's. No smoke in exhaust or other issues. This is a bone stock truck and other than going back with ARP studs, I don't plans for any real performance upgrades.
What all should I have done to the heads and any special instructions for the machine shop? I know the usual, check for warpage or cracks, but should the heads be machined off a couple thousandths? I'll probably get the valves reground and guides/seals checked, but should I recess the valves any particular amount?
How tight are the tolerances in a stock LLY motor from valve to piston top? I'll be using Grade C gaskets. Do I need to do the clay test piston top check or can I just bolt'er up?
Thanks for any input.
Jim
Jim
