cylinder distortion
mainer
Nov 11, 2008
326
interesting craig
we still on for tomorrow ? for my dropping off that 24v block/ head??
i'll try and call you in the morning
maine04max
Dec 11, 2008
1,009
yes we are i will probably be at heaths so if u want you can drop it off there to cut down on travel time
KEVINL
1,431
Phoenix, AZ
I don't think so if you were able to do that with your hand the bores would be ovals
bonescarolfi
Sep 3, 2008
223
Marshfield WI
I actually did something like that on my first day at tech school with cylinder sleeves out of semi engines. The teacher put the gauge in and had everybody push on the sleeve to see how little pressure was needed to distort the sleeve enough to make the gauge fall out. Didn't take much.
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
we did something similar to this the other day. and it will amaze you how much these engines move and why torque honing is good.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Cool demonstration, but everything bends. Everything...
Back when the laser was first coming out (~1970, I was in grade school), I went to a demonstration at General Dynamics. They had a 12"x12"x12" cube of glass. Solid. They shined a laser through it. Then the scientist rested his index finger on it, and it showed the distortion going in about 1/2 way through the block. Sure it was less than a millionth of an inch, but it bent. My machines at work are 10" thick solid granite and they distort a few ten-thousandths when loaded.
Now as far a deck honing goes, it's a good idea. But no stress they can put on the deck plate is going to match the cylinder pressure itself. Cylinders will always change shape under load, or you would not need pistons rings. Ever see a Cox model airplane engine? High compression yet they have no rings. The bore is so small and so accurate, that the piston seals very well without rings.
Back to the demostration, I think a dial indicator would actually make a useful demonstration.
13,713
774
So you don't think deck plate honing will help prevent distortion of the cylinder when the head is bolted on?
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Want to know something more interesting? You prolly already know this though:eek:. His finger never touched the glass. Repulsive Force! Just like the cylinders never touch the piston or rings.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
