LLY: Current Project any Thoughts
Bill H
Street Toy
Aug 25, 2011
VA
I,m just finishing up with installing a 4094R Garrett Turbo, cp3, Lift Pump, Stage 5 tranny, shim kit, new intercooler, ppe exhaust manifofds 4" banks exhaust no kat, I curently have ppe hot +2 programer. Does anyone have any thoughts on dangers and or beware OF ? I will likely be driving on level 7 or 8.
160,000 miles.
EFI thoughts ?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
no head studs? you definitely need efi to get the most out of your set up. you should have a low 12 high 11 sec. truck with those mods. cross your fingers that she holds up for while.:thumb:
Dirtymaxx03
3,109
With those mods you would benefit greatly from Efi live tuning. PPE makes great tunes for mostly stock trucks. Once you start adding turbos to the mix and larger cp3s etc, Efi really shines.
Bill H
Street Toy
Aug 25, 2011
VA
If I did the Rods & head bolts , I spose it would be $$ well spent to do the molly coated pistons at the same time.
