Curious what it's worth
GMC-ya!
54
5
Hey guys, been a member for a while but haven't posted a whole lot. I checked another forum but I know this is the one to come to about duramax trucks. I just want some opinions on what my trucks worth and you won't hurt my feelings. Might be a long post. Same truck in the sig. 02 GMC SLE 4x4 crew cab 268,xxx miles 4x4. The injectors are on their way out as the truck smokes at idle considerably but starts and runs fine. The rocker panels are shot and the cab corners are getting there. All the leather is in pretty good shape besides the drivers seat which is worn. The fuel gauge does not work and all the lights for the radio buttons are burnt out. The truck has some scratches and dings in it but doesn't look like a complete pile. I did the pump rub upgrade shortly after I bought it in 06. At around 180k I put a new cp3 pump in it. At around 220k i put a water pump in it. Recently I had a guy spray some rhino liner type stuff along the bottom of the doors to protect it from rock chips. While it was on the lift we replaced the whole front end and the old rusty rear diff cover. It has a new set of bfgoodrich AT tires on it. all of this was done right around the time that the truck began smoking at idle heavily so it has been parked (still needs an alignment after frontend rebuild). The Truck has never been raced pulled or any of that. It does have the PPE tuner on it but after 1 limp it has been set at level 3 and only daily driven. I'm sure I left some stuff out but I just wanted to get some opinions. Like I said, you won't hurt my feelings. Thanks in advance.
GMC-ya!
54
5
Thanks for the responses so far guys. I'll see if I can figure out how to post some pictures this weekend.
GMC-ya!
54
5
I'm in central Ohio. I'm not very computer savy so I'll try to get pictures figured out this weekend when I don't have school/work.
