After cutting the lips on my pistons , I have noticed with big weight behind me on small tunes that on the botton end lugged down to 1800 on grades that I feel just a hair less botton end .
I might be crazy , but I would guess this is the lip missing and combustion not being as good on low end .
Thoughts ??
Johnny
Rods are not bent they come with the caps angled like that but there does look to be a small hole in that piston
Which would mean, to me anyways, that your tune could use some adjustment to either the pulsewidth or timing or both in that RPM range so that the fuel shot is concentrated on being in the bowl rather than too much before or after TDC and spraying the tops decreasing the mixture quality in the cylinder????
