Cruising egts
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
The tune i have in my truck has a 450-500 degree egt while cruising at 70-75 mph unloaded. The tune i run has a 3000 pw and a 26* timing max ramped up after 2000 rpms. My question is it too low? Is it okay where its at? Over the years the various tunes i ran were usually in the 6-700 degree area cruising 70-75 mph
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Mine sits in the 600-700 deg range while crusing , but i run pretty low timing down low to help with spooling . If the fuel economy is good and you are happy with the spooling i wouldnt worry too much about it .
13,746
821
I've always seen the same EGTs as Trent. To be honest, I don't really remember the twins dropping my unloaded cruising EGTs by a significant amount over just the stock turbo. Could your EGT probe or gauge be bad?
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
how low of timing down low? i have low timing as well and it spools super fast; it rips the tires off:D economy isnt bad either (18.5 mpg hwy) the only quirk i have is during hwy cruising in 5th, it takes a while to spool the turbos if i stomp on it, to race someone doing a hwy roll on, i have to lock out 5th and get the rpms up to spool the turbos and then engage 5th and its pretty much all over for most people:rofl:
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
egt probe and guage works, it hits 1450-1500*f over 110+ mph at wot
TrentNell
Jul 7, 2008
7,543
slc tuah
16-2000 rpm is like is like 4 deg , if you blanket the turbo's and ( if you havent already) all the piping it will really help when the converter is locked , I noticed a good improvment .
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
wow, thats pretty low, i should try that. mine is like 12* at 2000rpms, also i did get a turbosock from levi for the s480, and it does make a difference
