02 Chevy, ever since I've owned it the cruise control hasn't worked. I'm finally getting around to working on it. First off I tested the switch, switch tests good, I'm getting signal. Then the previous owner had the clutch pedal switch removed and looped the connector, I installed a new CPPS, I have signal from the turn signal switch and down at the pedal connector. My question is. Will the cruise control work with the abs light on? I know the system cuts cruise when abs is active for more than 3 seconds.
