More info on the injectors?
They are very big, I had them in my hands and you can see the holes from 10ft back. You need to run a Bosch standalone to use them. Wagler shop is an amazing place to see first hand. Wes and Jeremy are some of the nicest people you will ever meet and I'm looking forward to seeing Cummins Killer stand up to it's name.
Are they duramax injectors?
They just ran the fuel line right into the head. Lift pump for each.
No, they're out of something a lot bigger. The head has to be machined to take this injector along with different valve covers. There is some crazy stuff going on over at Waglers and thank god they found someone like Kusileks to be able to try it all out.
