Crank position relearn?
DDiesell
plus.google.com
Working on a 2016 lml. Truck had a broken crankshaft. Replaced crankshaft. Does crankshaft position need to be relearned? I know it does on some GM vehicles. Truck runs and drives but has p02CD cylinder 1 injector exceeded limits and p02D3 cylinder 4 injector exceeded limits.
Sent from my SM-G965U using Tapatalk
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
I believe that’s only gas vehicles and it would throw a code specifically for the crank position relearn, but they generally relearn by themselves.
1,068
The relearn syncs the proper timing sequence.
Any time you change a cam or crank sensor, and ECU, or in this case the crankshaft, You should perform a relearn.
The generic data Is good enough for it to run but sometimes there are variances that could be outside the expected range. This is when you would get a code.
DDiesell
plus.google.com
My modis says the relearn is not supported. The only numbers that I can see that are off are injector command (ms). 1 and 4 are alot lower than the rest.
5,813
cam and crank sensors as well as reluctor wheels are fixed. There is no variable timing on a LML so there is nothing to relearn.
DDiesell
plus.google.com
I swapped injector 1 with 7 and no change. So obviously not an injector issue. IQA values are all set correctly. Is there a way to reset fuel tables on LML?
13,712
773
Were the valves adjusted correctly? Have you checked compression?
duramaxnate
Professional Amateur
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
Did the crank break at the front of the engine where they usually do? Reason I ask is because Cyl 1 is the first cylinder in the firing order and Cyl 3 is the last one. I have seen though (not on lmls but same concept I would assume) when a crank breaks, it can possibly do some damage to the connecting rods, Some have twisted and I have seen some bent just the slightest. With "short" rods, that would throw off cyl compression making those two injectors not happy campers.. That is the only thing I could honestly think of.
DDiesell
plus.google.com
Rods all checked out. Same injectors as before. Everything is in time. Compression is good in all cylinders. I did a reflash to reset all of the fuel tables. Now it has injectors 1,3,7. Sounds like it has fuel knock like injector timing is advanced.
DDiesell
plus.google.com
Update. I read something about driving the truck from 40-65 and repeating it about 30 times to relearn. I tried it. No codes now and truck runs smooth.
