"Crank Holders" and "Fuel Jets"
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
:confused:Looks good to me, I just put knew crank holder in mines truk gained some whores power two dem fuel jets spray fuel at the bottom of dah can lookin things the dah crank moves up and down in dah block, the fuel on the bottom of the can lookin things help even out the tempature from top to bottom to help prevent crackin.
Any1 wit questioin fell free two ask me
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Those are indeed the Fuel Jets off the short-lived 2-stroke piston-port Duramax.
They spray the fuel into the crankcase, where it mixes with air, then travels up the transfer ports to the chamber.
I was going to run one of those engines until I got a quote for getting 8 custom expansion chambers for it. :(
I was going to put it in a Quadracer, until I found out that Wade had already drawn up blueprints for it and had a patent on it.
IIRC, Wade sold a member here a block without the crankholders because they are optional on a Duramax, and just make rebuilding the engine that much harder.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
X2, oil pan holds crank in just fine on my motor. I can also spin the crank faster with no holders. You guys are missing out by using these dumb holders for your crank.
