LB7: Cracked filter housing?
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
I think my fuel filter housing is cracked on the lb7. It keeps losing prime about every 2 days or so. Would my filter housing from my lbz fit the lb7? I was thinking of taking it off the lbz anyway since I have the airdog and filters on the truck. Anyone know if this will work of know if where I can get one cheap??
1,941
The LBZ one should be the same as the LB7 one. I think thats the one thing GM didnt change over the years.(Yes, I know Im probably wrong about that, and I fully expect to be beaten up for it later) :)
Ever think its just the diaphragm and/or orings going bad?
Vasbinder
282
Floresville, Texas
My truck lost prime because the water separater on the bottom of the fuel filter had a crack. it dripped real slow and left me on side of the road. I need to get one of them filter wrench
13,735
804
I can tell you the LBZ fuel filter housing is not a direct swap for an LB7. Physically, it will bolt in, but the lines are pointed differently on the LB7 than they are on the LBZ.
That said, I would check the WIF sensor first. Maybe swap the one from your LBZ in there and see if the problem persists.
1,941
See? Told you I was probably wrong. :rofl: Id still look at the orings and diaphragm to be worn out. Cmon....its 9 years old.
I know I have to change my bleeder oring because fuel seeps there.
1,941
When it rains me out of the fields I'll have a little time to check it out further.
Are you harvesting alfalfa? I think thats what is being hauled around my area right now (Im still a "city guy").
durallymax
Apr 26, 2008
2,756
Under The Hood
depending on the area many people are still doing 1st cutting others are starting 2nd cutting. Some are cutting oats, or just plain old hay for baling.
And some people still have some late planting to do.
