Hey guys what's the best rubber line to use when replace the rubber lines on the cp3, also is there any better clamps to use than the factory one, or the little hose clamps??
any correct sized rubber fuel line from napa or something will work perfectly fine. As long as its rated for diesel.
I always reuse the factory springy clamps; not like theres really any pressure there on those lines or anything. (ok theres a little bit of pressure if you have a lift pump, but ive never had a factory springy-type clamp leak)
