Hi guys,
I have a LB7 that Im fitting into another vehicle, the engine is 'new' but has been sitting for a long time (2003 model).
The problem I'm having is I cant get rail pressure, I have just done a basic return test and I got 95ml from the main return after 15sec cranking.
I then removed the cp3 return and tested again, it looked like around 10ml from injectors and a lot more (didn't measure it) from the cp3.
Does that sound possible? Is there anything else I can check on the CP3 that might be damaged from sitting around for a long time?
If anyone has a pic of the correct hoses I should be testing that would be great too.
thanks!
thanks!
